Question PC booting, Display and USB dont work
Feb 1, 2022
Hello
I Built myself a pc 6 months ago, no problems until now.
I recently moved my computer and unplugged everything, now that I try to turn it on the power goes on fine, but USB devices wont work and display wont show anything either.
I looked up a few threads and I tried cleaning my computer and ram slots, but no change. Some threads say its a RAM problem, some say its PSU and some say MOBO.
I need help figuring out which component is actually the problem.
All parts expect are 6 months old, expect the gpu wich is 2 years old.
Taking display from MOBO instead of GPU has no effect.
Asus PRIME B450-Plus
Ryzen 5 3600
Kolink Enclave 600W
HyperX Fury 2x8 DDR4 2600mhz
Gigabyte GTX 1070
taylorwallace9
72
Having the exact same issue, PC boots but no display. My Razer mouse lights up but HyperX keyboard does not. I've tried another 6+2 PSU cord to the GPU (GTX 1070 as well) and still nothing. Im unsure if its a bad GPU or PSU.
taylorwallace9
72
Okay so I have dual channel ram, 32gb. I just removed one stick and now its working as normal. But at the same time, I kept the display cable (display port) unplugged. I plugged it in AFTER booting the PC. Im going to keep playing around and try to determine if its bad RAM now.
Edit: I turned the PC off, and again no display so I don't believe its a RAM issue. It seems to give me display once the PC is running, and then inserting a display cable.
