Pc boots, but graphics card and peripherals not working
francisco12lange
Hello, i recently bought a new cpu after having troubles with my older one. I put all the parts together again and the pc boots, it doesn't beep, and nothing appears on the monitor, and my keyboard doesn't turn on its lights.
Whole specs are:
Motherboard Asus M5A7BL-M/USB3
Cpu amd fx 6350
Gpu nvidia gtx 1050ti
2x4gb kingston ram sticks(can't remember the frecuency).
I've tried a few things to at least get image on the screen but nothing happens.
Thank you.
bfcallan
168
23
Sorry no one has responded yet, but try double checking all of your power connectors and other misc connections on the motherboard. It may sound elementary but it happens. Also, is this 6350 new, or was it bought used? Lastly what were the issues you were getting with your last processor?
francisco12lange
No worries, the 6350 is used, though it looks perfectly fine.
My last cpu had some pins bent.
Im rebuilding the pc and I'll check if it's still not working
