PC boots but nothing comes up on screen as well as repetitive irregular sound coming from tower.
Fufufuwie
Hey there,
This problem used to be intermittent, now it happens all the time. Here's the error message I used to get before the screen completely blacked out on me: http://i.imgur.com/sFsHwGI.jpg
Attempted troubleshooting:
This happened after I moved so I thought that maybe it was the outlets. It made sense to me because the outlets were loose so I assumed my PC wasn't getting power and so I relocated it. It didn't really work but it did bring my PC back on. (Or maybe it was a coincidence or a power cycle just helped.)
I did a bit of looking around and apparently I was told that my processor, power brick, or ram could be the problem? I'm not sure where to begin and what would be easiest to deal with first hand?
I checked my VGA cable/port, and I suddenly noticed that my PC was making a irregular sound that kept looping that never occurred before.
I also tried unplugging it for a good while and removing the power cable from the tower for a bit and even replaced it and there was no change. 🙁
I haven't checked inside yet but I wanted some more insight on the issue. I don't know very much about my case because it was put together for me. However, I have no problem carefully tearing it apart to find any information.
Side note:
I apologize if I chose the wrong category. After much research, accidental overclocking was a repetitive term.
Can you post your system specs here so we know what we're dealing with?
Also, from some looking around, I found this little post in Overclock that might help.
http://www.overclock.net/t/324052/ganged-vs-unganged-mode/10#post_4834217
To summarize, it might have something to do with your RAM being run in Unganged mode and failing to reach it's rated speed, causing it to slow down.
Might also be a symptom of your power supply dying but you can't be sure unless you have an AVR/UPS lying around to help stabilise your supply to the PC and eliminate the wall socket being a problem. If you have a spare PSU, it would help with testing too, but it'll get really troublesome unplugging and plugging all those cables between boots :|
