First off, the components:
The problem is, when I install the GPU, the 'EZ Debug' LED marked CPU flashes red once when I press the power button, and no fans spin up and no LED's light up. If I remove the GPU, the computer boots completely fine and I have installed windows, updated my BIOS, updated drivers and spent several hours trying to get the bloody GPU to work.
Things that I have made sure of are: GPU inserted correctly, GPU power connected properly, BIOS is set to use dedicated GPU rather than onboard graphics and that the GPU works, I tested it in my old pre-built system.
A friend recommended I check the nVIDIA control panel and check some settings there, however, it is not on my computer at all, I have followed a guide that shows you how to find it hidden in the control panel, however, it was not there either.
I am completely out of ideas and would appreciate any advice.
tl;dr
PC boots fine without GPU, with GPU installed properly, no post.
■ Motherboard: MSI H310M Gaming Plus
■ CPU: Intel i5 8500
■ RAM: 2x4GB Corsair Vengeance DDR4 (2133MHz)
■ GPU: ASUS Strix GTX 960 4GB (note, the GPU has been tested working and was pre-loved)
■ OS: Windows 10
■ PSU: Thermaltake Litepower 600W
tl;dr
