[SOLVED] PC boots for a bit then goes to restart
Dec 25, 2021
12
My PC works fine but whenever I boot it up after like 30 seconds it hits a blue screen of death restart. After the restart, it runs fine with no real issues. It is very annoying is there a fix for this?
You can follow those steps for the fixed blue screen of death:
  • Uninstall incompatible software.
  • Run a memory checker.
  • Check for hard drive errors.
  • Remove non-essential peripherals.
  • Replace defective or incompatible expansion cards.
  • Run SetupDiag after a failed Windows update.
  • Perform a clean install.
