My Budget is around 800 bucks. Currently, I'm running at 770 bucks with rebates. That's fine. But is there something I should upgrade for a little more cash, for better results?
http://pcpartpicker.com/p/BPXgWZ
Things I don't want to part with:
The OS (already secured)
The Ram (CL 9, 16 gigs, great stuff)
The Case (it's so darn cool! Get it? COOL?)
The GPU is my point of focus. Should I get a better version of the same GPU? Is there a much better version for only about 20-30 dollars more?
Is the power supply good quality? If it is, I'll gladly keep the overkill wattage. It'll be useful for future upgrades.
Thank you guys so much!
