PC build 800-1000$ ( MAX 1000$)
Valsoray
18
Hello I am about to buy a new PC.
I am wondering about Intel Xeon E3-1231 v3 / Intel I5 i4690K
What motherboard will be best ? Maybe I want to overclock in future -> Do i need better fan/ cooling?
What Mhz / size should I buy? 2x 4GB / 2X 8GB? 1600 or more?
Should I add the SSD ? (if not over 1000$ or I can buy it later)
Thanks for every reply!
There is my current build I made
http://pcpartpicker.com/p/XqyrdC
If you want a gtx 970 for shadowplay could you go with this,
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($242.99 @ SuperBiiz)
CPU Cooler: CRYORIG M9i 48.4 CFM CPU Cooler ($25.99 @ Newegg)
Motherboard: ASRock Z97 Extreme3 ATX LGA1150 Motherboard ($82.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 Memory ($72.99 @ NCIX US)
Storage: Zotac Premium Edition 240GB 2.5" Solid State...
What is the purpose if your going to game drop the Xeon. Xeons dont like being overclocked and the i5 would do better in that field, if you are editing video or content creation the xeon will be better. also in gaming the MHz of ram doesnt matter. always try for an SSD it makes life alot better.
PCPartPicker part list: http://pcpartpicker.com/p/6w6wRB
Price breakdown by merchant: http://pcpartpicker.com/p/6w6wRB/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor ($314.99 @ Amazon)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler ($27.99 @ Newegg)
Motherboard: ASRock Z170 Pro4 ATX LGA1151 Motherboard ($102.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory ($74.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($87.89 @ OutletPC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($63.99 @ NCIX US)
Video Card: PowerColor Radeon R9 390 8GB Video Card ($279.99 @ Newegg)
Case: Deepcool TESSERACT BF ATX Mid Tower Case ($41.98 @ Newegg)
Power Supply: XFX 750W 80+ Bronze Certified ATX Power Supply ($78.99 @ SuperBiiz)
Total: $1073.80
Generated by PCPartPicker 2016-01-21 11:42 EST-0500
a bit over your budget ...but a solid build
could you make some changes to get under 1000?
I think about gtx 970 because of shadowplay and better optimalisation, i have no experience with asrock either.
I7 is too much.
``Gaming, video capture, editing and render ``
if you want to do this..?? you really need my built above
if you want a lower budget rig see here
PCPartPicker part list: http://pcpartpicker.com/p/V9LZ6h
Price breakdown by merchant: http://pcpartpicker.com/p/V9LZ6h/by_merchant/
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor ($216.95 @ SuperBiiz)
Memory: GeIL EVO POTENZA 16GB (2 x 8GB) DDR4-2133 Memory ($69.99 @ Newegg)
Video Card: Zotac GeForce GTX 970 4GB Video Card ($303.88 @ OutletPC)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply ($64.99 @ SuperBiiz)
Total: $980.65
Generated by PCPartPicker 2016-01-21 14:52 EST-0500
this build meet your budget , but is a lot less powerfull
``i have no experience with asrock either.``
SO WHAT??
``Oi, tone it down a little. No need for shouting or repeated punctuation.``
i do not want to be aggressive , the thing is the op ask us to give our idea on a build and after he dictate us ...
``I think about gtx 970 because of shadowplay and better optimalisation, i have no experience with asrock either.
I7 is too much. ``
Storage: Zotac Premium Edition 240GB 2.5" Solid State Drive ($74.99 @ Amazon)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($63.88 @ OutletPC)
Video Card: EVGA GeForce GTX 970 4GB SSC ACX 2.0+ Video Card ($309.99 @ NCIX US)
Case: Fractal Design Define R4 Blackout ATX Mid Tower Case ($64.99 @ NCIX US)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ NCIX US)
Total: $998.79
Generated by PCPartPicker 2016-01-23 07:00 EST-0500
i don't record so don;'t know if it's the way to go.
This build has everything for sli as well.
The R9 is an as good gpu for less right now so keep that in mind.
