[SOLVED] pc build advice.
Blazing_89
Commendable
May 30, 2017
6
I'm looking to build a new PC around a AMD Ryzen 7 3800x CPU. I would like the PC to be able to run any high end games at 100+ fps in 1440p resolution. My budget is anywhere from $1500-$2000. So far I have the CPU and samsung EVO SSDs.
With that budget and the CPU already bought with the SSDs you can get the best GPU at the moment. Took the 850Watts instead of the 750Watts since it was 5 more bux. You can still add more RAM and change to a better board if you want. You can change the board to the WIFI version if you need Wifi on it.
Or you could wait for the new RTX 3000 series releasing.
PCPartPicker Part List
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler ($89.00)
Motherboard: Gigabyte X570 AORUS ELITE ATX AM4 Motherboard ($199.99 @ Best Buy)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory ($77.99 @ Newegg)
Video Card: MSI GeForce RTX 2080 Ti 11 GB GAMING X TRIO Video Card ($1209.99 @...
Video Card: MSI GeForce RTX 2080 Ti 11 GB GAMING X TRIO Video Card ($1209.99 @ Newegg)
Power Supply: Corsair RMx (2018) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($144.99 @ Best Buy)
Total: $1721.96
Generated by PCPartPicker 2020-05-13 08:37 EDT-0400
Reactions: Blazing_89
