Hey there,
I'm currently looking to build a new gaming/work computer and wanted some feedback/confirmation on the compatability of the parts and some concerns that I've had. The build consists of the following parts, however, I'm open to suggestions if there's an alternate Case/GPU/CPU that you'd recommend instead.
CPU - Ryzen 5 7600X
GPU - Gigabyte GeForce RTX 4070 WINDFORCE OC 12GB
RAM - Ram Corsair Vengeance DDR5 32GB 2x16GB 5600MHz
MOTHERBOARD - MSI MAG B650 TOMAHAWK WIFI
CASE- Geh Antec PerformanceOne P20CE
PSU (currently own this one) - Seasonic CORE-GM-650
Questions:
1. Would my current PSU would be capable enough for this build or would I need to get a new one? If so, which one would you recommend for the build.
2. Would the build be compatible with each other and would I be able to use it straight out of the box without any other preparations?
3. Which CPU cooler would you recommend for the processor? I'm not looking for something high end, just for something that'd do the job.
Thank you for taking the time to reply and I'll be waiting for the replies!
CPU - Ryzen 5 7600X
Questions:
