PC build and case suggestions?
steveb531
141
I have a pc build in mind which i am pretty confident about however i cant find a case that i am really happy with. Its a green and black LED theme ive got going on and want the case to matc that. Ive found some nice cases but they all seem to be missing something on my list of features.
I would be grateful if you guys could point out any improvements in my build that could be made without increasing the cost and/or recommend a case that fits the criteria or a close comparison.
Also is there any benefit to me using several 4GB ram cards over 1 or 2 8GB?
Case:
1 > 2 Front intake fans
2 top fans/ top expansion space for water cooling
1 > 2 side fans
1 back extractor fan
Expansion space for bottom fan/PSU fan
Green LED
>£60
Build:
Intel i7 4790K
MSI Nvidia GTX 970 Gaming (Owned)
Asus Z97-AR
750W EVGA Bronze 80 PSU (Owned)
1TB HDD
1x 8GB Corsair Vengeance RAM (16GB Later Upgrade)
840 Samsung Evo 250gb SSD (Later Upgrade)
Corsair H100i/h105 (Later Upgrade)
Cheers
With the ram not really as long as its running on dual channel all is good!! As for your system, it`s very nice and a nice system needs a nice chassis!!
http://www.coolermaster.com/case/mid-tower/cm690-nvidia-edition/
There you go... Bobs your uncle!!
High Performance Cooling Advantages
Phantom's extensive cooling capabilities include 7 fan cooling option with
Dual 200mm
Single side 230/200mm*
Triple 120mm
Front 140mm fans.
For enhanced control and expandability, NZXT includes dual radiator support, quad watercooling cutouts, and an integrated fan controller with up to five 20W channels
*NZXT only guarantees fitment with NZXT's FN-200
Straight from their site
http://www.nzxt.com/product/detail/34-phantom.html
Since they state dual radiator support i assume but i cannot verify do some research you might find someone whose done it :)
