PC build and PSU help??
kmcmorrow135
25
So I'm planning on building a PC to get into PC gaming but I'm not very smart when it comes to PC parts in general so could somebody please give me feedback on the build I have planned below and tell me if all parts are compatible and if it is a decent build in general. Take note I won't be playing many demanding games.
PC specs:
CPU: AMD Ryzen 3 1200
GPU: Gigabyte GTX 1050 ti
Motherboard: MSI B350 Tomohawk
RAM: Crucial 8gb DDR4
STORAGE: Seagate Barracudda 1TB
CASE: CiT Vanquish
PSU: (read below)
Sorry if I made an obvious compatibility error with these as I said above I'm not great with stuff like this haha.
Could somebody also recommend me a power supply that would suit this particular build?
I would greatly appreciate any feedback or recommendations :)
Depends on your location.
Right now, in the US, you can't really go wrong with the SeaSonic S12II 520W
Power Supply: SeaSonic - S12II 520W 80+ Bronze Certified ATX Power Supply ($30.98 @ Newegg)
Total: $30.98
Generated by PCPartPicker 2017-08-18 14:03 EDT-0400
It's a little bit of a dated platform, but for the price, it's a steal.
The CX450M is another solid option for a very reasonable price
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply ($39.99 @...
Total: $30.98
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply ($39.99 @ Amazon)
Total: $39.99
For your RAM, I'd ensure you get speeds ~3000MHz. Ryzen really does show gains from faster memory.
Cant comment on the case as I've never seen it, but the rest is a pretty well balanced, budget, 1080p setup.
Make sure you overclock that Ryzen3 though, as there's quite the gains to be had through a modest OC (should be able to see 3.9GHz at stock voltages)
