Question PC build /case airflow
Sep 9, 2020
HI, I've been looking for a case for my build I'll be using the ryzen 2700x used with its stock cooler with a rtx 2060. I was thinking about the nzxt h510 until i read a bunch of negative things regarding its cooling, which I'm not knowledgable about. So would that be fine esepcially using that cpus stock cooler, or does anyone reccomend a better case, I don't really care about looks, just perfromance/cooling mainly, thanks .
Lutfij
Please include your (proposed?)system's specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Case:
We can also make do with a budget for a chassis, where you're located and your preferred site for purchase so we know what you have access to.
curley81
Great
Sep 12, 2020
60
6
65
7
HI and thank you, I already have most my parts for a while I just havent gotten around to building it, I just need a case which I cant decide on (mainly regarding cooling). this is everything I have so far https://pcpartpicker.com/list/7BMRL2
if you want good air flow then get a mesh front and a large case with extra fans but if you do i suggest you invest in one of these for regular removal of dust
https://www.amazon.co.uk/gp/product/B01G1Z0RF0/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
best bit of cleaning kit I have ever bought
dimtodim
Respectable
Sep 4, 2018
680
64
1,990
14
what cpu cooler u will use?
