PC Build (First Ever)!!!
Mar 13, 2018
32
So I'm looking for advice on the components list of the build and wanted to hear your advise.
Games I would play are Fortnite, Overwatch, CS: GO, PUBG, Battlefield, R6, and others.
Parts List:
Ryzen 3 2200G
580 4GB/570 8GB/1060 3GB (Which Should I Get?)
Asus ROG Strix B450-F ATX
1TB WD Hard Drive
1x8 HyperX 2666MHz DDR4
Corsair CX 650W PSU 80+Bronze
NZXT H500/Phanteks Eclipse P300 Mid Tower Case
Cheers.
No ssd?
The 580 is the best of all of them.
Get the fastest ram you can get AND in a kit. Ryzen needs dual channel to perform well.
What cx 650? There are multiple version. Some terrible others ok.
The P300 has better ventilation.
Hi there,
Appreciate this is your first build so ill try and be as clear as possible.
Here are my issues with your current build:
No SSD for OS worth getting one! Though its not necessarily a must have, it'll speed your system up by a huge amount. Even if it is a 120GB SSD that should do it.
Where most of those games are not very spec demanding, youll struggle with running battlefield and PUBG with the 5 series GFX. I'd go for the 1060.
RAM could also be an issue in some games, i'd recommend getting 16GB DDR4!
Have you also thought about fans for your case?
I dont get what you mean by me struggling with battle field or pubg
He means low fps. Which is not true as the Rx 580 is more more powerfull than the 1060 3gb.
Had a bit of a moment at the time where i thought the OP meant GTX 5 series -_-
