hi, we are building a pc for cs go and cs2, i would like to ask if everything is ok, the 240hz monitor is called xl2540k.
I don't rule out playing other games, but I think it will do very well anyway, I want to not make any changes for a long timeThe specs are pretty OKAY and good, but kind of "overkill" for playing just CS:GO and CS2. For other latest graphic demanding games those specs might help more in gaming, IMO.
thanks for the answer,OK.
I have some thoughts:
Don't be penny wise and pound foolish saving $25 by buying a F suffix processor.
If you ever have a graphics issue, integrated graphics can bail you out.
Games are getting larger. I would buy a 2tb m.2 device up front.
Intel 670P is usually a good deal.
A aio cooler does not last forever.
In time the mechanical pump fails or gets clogged. Air intrudes and the unit will need replacement.
Think 5 years.
A good twin tower air cooler will do the job just as well and probably cost less.
RTX 3000 series and modern cards can have high power spikes well above the nominal power draw.
850w might be more appropriate.
And, look for a 7 to 10 year warranty for a quality unit.
Corsair RMx or Seasonic focus/prime for examole.
For the very best, Noctua NH-D15s. It is 160mm tall and fits your case.thanks for the answer,
what kind of cooling are you talking about exactly?
hm, you think dh15 won't fit? dh15s can handle CPU overclocking?For the very best, Noctua NH-D15s. It is 160mm tall and fits your case.
It uses a quiet 140mm fan.
The NH-D15 is a marginally better cooler, but it may conflict with your ram heat spreaders.![]()
NH-D15S
Tailored to provide superior RAM and PCIe compatibility, the NH-D15S is an asymmetrical single fan version of Noctua’s award-winning flagship model, the NH-D15. Thanks to its asymmetrical design, the NH-D15S clears the top PCIe slot on most µATX and ATX motherboards. At the same time, the single...noctua.at
If you want to go cheap, a thermalright peerless assassin twin tower with 120mm fans could work.
Do not be overly frightened by claims of heat with 13th gen processors.
They perform best when pushing the thermal limits(100c.)
Read this article on running 13th gen with less than maximal cooling:
In video form:![]()
Core i9-13900K Cooling Guide: Testing Intel's Flagship With Budget Air and Big AIOs
The Core i9-13900K can push even the most capable liquid coolers to their limits, but you don’t lose that much performance if you go with budget-priced air cooling.www.tomshardware.com
View: https://www.youtube.com/watch?v=dNFgswzTvyc
I understand that the slot for the graphics card will not be covered by either one? I put the gskill memory in the basketnoctua maintains a list of suitable coolers for different processors.
Here is the list for the 13600k:
Both NH-D15s and NH-D15 are as good as it gets on the list.INTEL Core i5-13600K | CPU Compatibility | Noctua Compatibility Centre
Series: Raptor Lake-S, Socket: LGA 1700ncc.noctua.at
As to fit, your case specs say 165mm tall coolers are ok. NH-D15 fits there.
But the possible issue is with ram clearance.
Your ram is 42.9mm tall.
Here is a diagram of the nh-D15:
there is 32mm clearance.![]()
NH-D15
Built on the basis of the legendary NH-D14 and carrying on its quest for ultimate quiet cooling performance, Noctua’s flagship model NH-D15 is an elite-class dual tower cooler for the highest demands. Its expanded heatpipe layout and two premium grade NF-A15 140mm fans with PWM support for...noctua.at
If the case had more room, one could move the fan up 10mm.
Or, use a 120mm front fan instead.
Or, mount the front fan in back.
or use ram that is 32mm tall.
g.skil ripjaws S5 might be one example
G.SKILL Ripjaws S5 Series 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model F5-6000J3040F16GX2-RS5K - Newegg.com
Buy G.SKILL Ripjaws S5 Series 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model F5-6000J3040F16GX2-RS5K with fast shipping and top-rated customer service. Once you know, you Newegg!www.newegg.com
thanks for your help, finally it looks like this:You are wise to check.
Some motherboards do have an issue with NH-D15. Some are vrm clearance, some positioned to close to the first pcie x16 slot.
No problem with NH=D15.
Noctua to the rescue again.
Here is their motherboard compatibility list for the
Gigabyte Z790 UD AX
Gigabyte Z790 UD AX | Motherboard Compatibility | Noctua Compatibility Centre
Socket: LGA1700ncc.noctua.at
hi, I have one more question, I got information that the store where I made the order does not have the z790 ud ax motherboard. Do you have any other suggestions, will the above mentioned motherboard be ok?You are wise to check.
Gigabyte Z790 UD AX
However, I took the nhd15s cooling, on the manufacturer's website, the nhd15 does not have very good ventilation in my case.What Z790 motherboards are available to you?
I have no particular brand preference.
Check for motherboard compatibility for the NH-D15.
Some asus boards have vrm coolers that might interfere.
Our motherboard compatibility list shows which Noctua CPU coolers are compatible with which motherboards. We indicate if optional mounting upgrade kits are required and if there are any restrictions such as when the heatsink overhangs the top PCIe x16 slot. Please use the filters and search...ncc.noctua.at
