Question PC Build for CS2 and Dota 2
28
What is the cheapest build to play at 240+ fps for Dota 2 and CS2 ?
I wanna play at 240+FPS in 1080 ultra settings or 240+ fps in 2k medium settings.
what processor and graphics card will be good ?
also if possible I want the build to be cheap.
Hey there,
What budget do you have in mind? Where do you purchase from? What country do you live in, and what's the denomination?
Realistically for that hz/FPS you need a really fast CPU and a GPU that can keep up with it.
Do you have a current build?
Right off the bad, I'd be suggesting a Ryzen 5xxx/Intel 12th Gen and a Radeon 6800XT or an nVidia 30880ti from the older gen parts.
Otherwise A Ryzen 7xxx/Intel 13th with a DDR5 base might be a good way to go.
Hey there,
