Pc build for flight simulator x
west171
30
ok im building a pc and need to know if the gtx560ti will play fsx on high - ultra high with good fps with a i3 2100 ive heard its pretty good with the 560ti and i7 but i7 is too expensive at the moment will it have good frames with this plus good graphics i havent seen any videos with the i3 only i7 and 560ti so yeah please tell me
COLGeek
37,928
9
112,365
4,981
As FSX is not all that demanding, you should be able to run at High settings (or better) just fine with a GTX560ti and i3. You shouldn't have any issues at all in terms of playability.
west171
30
so you rekon it will be sweet with those two beacuase i heard it pretty much depponds on cpu more than the gpu
Rockdpm
Splendid
Dec 26, 2011
4,440
152
Yea you are right i played it yesterday, idk if you want to get a lowend core i5. but the Core i3 should be plenty. the thing that supprised me is the game recommends 6gb of ram.
west171
30
what where i read it only needed 512mb but i plan on getting 8 gigs so i should be sweet so what are you running
Rockdpm
Splendid
Dec 26, 2011
4,440
152
Yes you will be fine. i3 and GTX 560 ti will be more than enough to handle Flight Simulator
AdrianPerry
2,859
154
i5-2400 will be better. However as previously mentioned, FSX isn't all that demanding so the i3 would work just fine.
i5-2400, H61 mobo, GTX 560Ti would be a really nice set up :)
Jump up the price range a little more, and get i5-2500k (over-clockable), Z68 motherboard and GTX 560Ti.
Tone it down a little, but allow for future upgrades....
i3-2100, Z68 motherboard, GTX 560Ti.
Cheapest option,
i3-2100, H61 motherboard, GTX 560Ti.
EDIT: If you post us a budget and let us know what websites/country your buying the components from, I'm sure we can come up with a build to suit your needs :) a build advice template can be found here: http://www.tomshardware.co.uk/forum/261222-13-build-advice
west171
30
ok thanks my budget could be anything at the moment realy but its my first build and i dont wana look like a dick and buy everything expensive i want to have a great graphics card like the 560ti since ive heard its good but i could get a beter one if its worth it around the same price um i think the i5 will be enough and i dont know anything else im getting but i want to be able to play fsx on ultra high or high with good fps also im in new zealand thanks:)
COLGeek
37,928
9
112,365
4,981
"More" PC is always better, in general, when it comes to the playability of both current and future games. Build the rig you can afford and have fun!
COLGeek
37,928
9
112,365
4,981
Yes, it will play just fine, especially if you get the 2500k version and overclock it a bit.
Similar threads
