Question PC build general question
Nov 27, 2024
Hello,
I just set up a new build on Newegg through their PC builder and just had the general concern if some components would not work with others. Was hoping someone (with FAR more knowledge than Myself) could look over the build list and just flat out tell me (yes this will work, or No you suck)
Link: https://newegg.io/918297c
If this link doesn't work lmk
Hello,
why did you choose 5700g with 6950xt cardYou have installed 2 PCIe Gen 4x4 hard drives (only one will work, the other must be PCIe Gen 3x4)
In AM4 the best processor you can put and at a good price is the 5900x at this moment and with this cardEverything else is ok
Also, on the CORSAIR 4000D, the water cooling you chose only fits in the front.
For the Graphics card i was looking for biggest bang for the buck.
As for the PCIe im looking for a lot of storage cause i game alot. will it not work because they will fight eachother if they are both 4x4?
the card is good, the processor does not do anything for the card, I told you what to choose, if you only play games and do nothing else 5700x3d, if you do anything else 5900x (it is cheaper)The disk can work for you at low speeds, so you throw away your money for the second one, but it can also create problems for you in Windows, so go to gen3 in the second one you want for storage
