Pc build guide
Sep 11, 2018
39
What's up everyone, since I was supposed to ask about all the components, I decided to put them all in one thread. My budget is from 450-550$. Want some suggestions for s good pc build overall.
A Budget of 550$ is definitly tight for a complete PC but i think this should work fine for 1080p 60+fps
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor ($93.29 @ OutletPC)
Motherboard: MSI - B450M PRO-M2 Micro ATX AM4 Motherboard ($64.99 @ B&H)
Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory ($79.99 @ Amazon)
Storage: Kingston - A400 120GB 2.5" Solid State Drive ($28.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($59.39 @ OutletPC)
Video Card: MSI - GeForce GTX 1050 Ti 4GB Video Card ($164.99 @ B&H)
Case: Rosewill...
Case: Rosewill - FBM-X1 MicroATX Mini Tower Case ($26.99 @ Amazon)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($26.99 @ Newegg)
Total: $545.62
Generated by PCPartPicker 2018-09-17 08:35 EDT-0400
If you want a different case without spending more money then you can downgrade the HDD to 1 TB or go without SSD which would give you 15-25$ more on a Case.
Keep in mind that you still need windows if you dont want that little notification in the bottom right all the time^^
Well, I really like the build, but I think I'll pass on the graphics card and get a ryzen 3 2200g and later on add a gtx 1070.
Regarding the case though, are there any tempered glass cases that come with RGB fans and has good airflow under 75$? And I don't mind if they're tempered glass and have some good controllable aesthetics without the fans because I can buy them separately.
Saving money for a 1070 is also a good option.
I dont really know what kind of Case i would suggest you. I love the Meshify C due to its clean look and mesh front and good airflow.. You can go for the Mini Version: https://pcpartpicker.com/product/JsKcCJ/fractal-design-meshify-c-mini-dark-tg-microatx-mini-tower-case-fd-ca-mesh-c-mini-bko-tgd
Other then that i am not really into RGB Fans. I do have a single RGB Strip from Cablemod in my Case and thats all 😀
I've found tons of tempered glass cases for under 60$, I can buy my own fans but I don't know which ones have the best airflow.
Something like the DIYPC Vanguard RGB Black is priced at 88$ but comes with 4 RGB and I can add my own, but the problem is idk whether it has good airflow or not
Another one is the Deepcool Matrexx 55 or the or the thermaltake v200
