PC BUILD, Help appreciated!
Haopeng Lin
36
MOBO: Alienware 0PGRP5
HD: SeaGate 1TB
MEMORY: Hyundai HMT451U6AFR8C-PB DDR3 8GB 2 Modules 1,600 MHz
OPTICAL DRIVE: HL-DT-ST DVDRWBD CA40n
CASE: Corsair Vengeance C70
Hi, my specs are above. I used to own a Alienware X51 R2. Since the death of my GPU, I decided to move it all into a new case and salvage as much as I can. Since I'm trying to get new parts I'll need a PSU and GPU.
My friend has a spare Corsair HX620W and I was looking at a EVGA GeForce GTX 960 SuperSC.
Is the EVGA any good?
Will the power supply cut it?
Any parts from the old computer I should trash?
Better replacement in the $200 range for GPU?
I need quite a bit of help hehe x.x
Any thoughts and help would be appreciated!!
i think cpu will be fine for now but in 2-3 years you have to change it cant say i think get yourself a good psu and how is is the max for gpu because you have written $200 and gtx 980 is above that
