Pc build help needed please
Girishu
66
Finally i am gonna build my very own pc and that too within 45k INDIAN RUPEES
Specs are
AMD FD6300WMHKBOX FX-6300 6-Core Processor Black Edition
Or CORE EDITION???????? Suggest
Gigabyte AM3+ AMD DDR3 1333 760G HDMI USB 3.0 Micro ATX Motherboard GA-78LMT-USB3
Gigabyte GeForce GTX 960 4GB GDDR5 PCiE Graphics Cards GV-N960OC-4GD
Seagate 1TB Desktop HDD SATA 6Gb/s 64MB Cache 3.5-Inch Internal Bare Drive (ST1000DM003)
Kingston hyper furyX memory DDR3 8GB (HX318C10F/8)
Corsair VS550 550 WATT PSU
Please give my your suggestions...and if any modifications to be done...please tell me I will be very thank full...
As I am semi noob in pc building
Budget is 45k inr and yes medium gaming not hard core...gta v,csgo,bf3, and some other in high settings.... and what is bad in that ? I AM FROM INDIA
What kinds of games will you be playing?
The FX-6300 is a couple of generations old and is usually not competitive with Intel.
If you will play multiplayer games, or games that depend mostly on the graphics card you will do ok.
If your games are sims, mmo, or strategy games, they depend on the performance of a single master core.
The FX cores are slow, and it will not perform well.
And there is no upgrade that can help.
For those games, you want Intel of some sort.
What modifications I should do to get it better?...BTW GTX 960 4gb Of version is not a bad card though I have seen vedios ... running gta v at Max at average or 50-60 FPS in 1080p and what modifications I shud do to get it better?
i3 6100
h110/b150 motherboard h170 if u can afford it
ddr4 2133 mhz 2x4gb
westerndigital 1tb+ 120gb ssd
gtx 950 or 960 if u can afford it the difference is not that big.
case whatever u like
and now the most important : seasonic s12ii 520w (really worth it !!) if not possible grab the antec vp 500w
The FX-6300 is still a pretty powerful chip for gaming, I had mine overclocked to 4.2GHz and paired with a GTX 970. Together they could handle everything I could throw at it.
If you can find good deals on eBay, I'd suggest finding an older generation i5 or i7 instead of the FX-6300. I don't know what it would cost in India, but I've found i5-3570's on eBay for around $100 US. That's a steal for a processor that's still very fast.
Code:
Why upgrade? I have not have built the pc yet I am asking suggestions...so should I change the processor which I listed to buy? And is evertthing OK? Mother board ,GRAPHICS card,ram,psu, and others
I play GTA V mmost of the time..then csgo,bf3, far cry 3, and NFS 2,rivals, and some other games
So I shud change the processor which I have listed?
Thanks for the quickly reply for every one
let me say it in very easy english
the intel i3 cpu is better than your fx 6300 and fx 8320
the i5 and i7 would outperform any fx cpu and u got that upgrade.
fx cpus come back from 2012 and are near dead and will bottleneck high end Gpus.
in short : i3 wins now and in the future
So I have to change the mother board,processor, that's it? Can u name that processor which is good for me...and cheaper is good, a good mobo for the processor u said,and which wont bottleneck the gtx 960...so u mean all are right except the processor and mother board??
can u give me the li is of those parts? I am finding difficult to find those parts...but the components which u said is little higher than my budget and anyways I will check it out..please drop links of those things in cheap price... which will be shipped to India
How will i3 win on fx6300?? Fx6300 have higher clock and more cores.. i3 is dual core and fx6300 is hexacore...I don't think i3 will beat fx
So that means I shud buy only the things which u have listed there?
But I am getting GTX960 4GB oc version for 13k itself...should i buy the card which u suggested ...or shall i buy which i told above?
You did not mention the processor their in that photo so that costs extra?
No in that link's photo...processor price is not there...now totally..everything in the image costs 35,679 rupees, I have left with 9k nearly
