PC Build Help, Non-Gaming. Work PC (Lots of programs)
Voidale
Hello Guys!
I need the best PC for work, this means lots of browsers, VM's, SSH's, VisualBasics,Programs. I need it to be super fast no lags.
What can you recommend? What components for this type of build are the most important?
I thought like i7 4770 + SSD. Maybe I should even look for dual CPU motherboard?
Also I will order the items in my country so if you can give like 1-2 options for each component if it's not available. I really appreciate the help!
Budget $1,000 + some room for expansion later.
Thanks!
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($198.98 @ OutletPC)
CPU Cooler: Noctua NH-U12P SE2 54.4 CFM CPU Cooler ($59.98 @ OutletPC)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard ($89.99 @ Microcenter)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory ($68.00 @ Newegg)
Storage: Crucial M500 120GB 2.5" Solid State Disk ($85.99 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ OutletPC)
Video Card: Asus Radeon R7 240 2GB Video Card ($69.99 @ Microcenter)
Case: Fractal Design Core 3000 USB 3.0 (Black) ATX Mid Tower Case ($49.99 @ Microcenter)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply ($34.99 @ Microcenter)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($14.99 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($88.98 @ OutletPC)
Monitor: ViewSonic VX2370Smh-LED 23.0" Monitor ($149.99 @ Newegg)
Total: $971.85
(Generated by PCPartPicker 2013-12-21 13:35 EST-0500)
Can you guys explain your picks? I can find builds for the budget myself as well... it doesn't seem you explain why you choose "x" also AMD never ever... only Intel.
