Pc Build Help - Which Mobo?
nerdygeek12
11
Hi There,
I'm in the process of building a gaming and video editing PC.
I've had a few parts given to me but found out yesterday that the mobo that I was given will not be compatible with my CPU.
Can anyone recommend a good MOBO. If you can would you also be able to recommend some good ram for it aswell.
I have:
CPU - Intel I5 6600K - https://www.amazon.co.uk/d/Processors/Intel-Core-I5-6600K-GHz-Cache-LGA1151/B012M8M7TY/ref=sr_1_2?ie=UTF8&qid=1483005713&sr=8-2&keywords=6600K
GPU - Vapor-X R9 280X 3G D5- http://www.sapphiretech.com/productdetial.asp?pid=33D28E48-DBA2-40E7-A9F4-D8265AD5B38D&lang=eng
HDD - https://www.amazon.co.uk/Blue-Desktop-Hard-Disk-Drive/dp/B0088PUEPK/ref=sr_1_1?ie=UTF8&qid=1483005694&sr=8-1&keywords=1tb
I have about £150.00 max to spend on the mobo.
I have found three that I'm interested in. Are any of these three any good? I'm mainly interested in the third one.
https://www.amazon.co.uk/Intel-Lga1151-Z170-Sabertooth-Motherboard/dp/B01ARORJF2/ref=sr_1_1?ie=UTF8&qid=1483005779&sr=8-1&keywords=sabertooth
https://www.amazon.co.uk/d/Motherboards/ASRock-Z170-EXTREME4-Extreme4-Skylake-ATX-Motherboard/B012D7HBTA/ref=sr_1_1?ie=UTF8&qid=1483005799&sr=8-1&keywords=asrock
http://www.ebuyer.com/720062-asus-z170-pro-gaming-socket-1151-vga-dvi-hdmi-8-channel-hd-audio-z170-pro-gaming
Thank you in advance.
