PC Build Help!!!!
Shaik Farooq
311
Hey guys this is what im gonna build
Here are the specs
i7 4770k
two gtx 760s
8gb ram etc
seasonic m12 750 bronze
asus z87 plus etc
Tell me if this setup is good enough for me especially for the CPU....
this is what I do mostly gaming like battle field 4 ,crysis 3.....then a little video editing,photoshop....programming...then that's preety much it
My budget is 3600 AED
I can buy parts only from this website
www.Gear-up.me
sure if it is a seasonic then ya go ahead. between bronze and gold isnt that much of a difference in reality, and you will be fine with 750 but if you want to get a 850 then thats fine, your computer wont blow up.
CM Nick
22
Hi Shaik,
Don't know if you actually need 2 graphic cards.
And why did you choose for the GTX 760?
Because here the GTX 770 is dropping in price and has better performance.
And I also cant keep under the budget of 3600 AED with your build.
In my opinion I would go for 1 good graphic card now and if you really need it, upgrade to 2 later on.
Shaik Farooq
311
Im really sorry i already have a gtx 760 and i will buy another one when prices go down but for know i need a cpu,mobo,ram psu and hdd .......ill buy the ssd later
Shaik Farooq
311
sorry for that.... luk at my previous post
Shaik Farooq
311
So yeah is the bronze seasonic 750 watt good enough for me?? or should i get 850wat psu
Because I will over clock my CPu to 4.2 ghz and i might add a 760 to current setup and oc the ram profile to 1866mhz??
Shaik Farooq
311
I can get a 850watt psu and i dont to cheap out on it and just to remind you this psu which is seasonic ms12 bronze not the X-series.......
sheag123
619
