PC Build Help
GraphicsNerd
69
Hi,
In a few months I am buying the parts to build a computer.
1. First I need info on the chassis. I am currently looking at the Rosewill Galaxy-02-A Black ATX Mid Tower PC Gaming Computer Case, and hoping it'll work, and if not, provide a case that'll work down below. I would like a chassis with the following aspects:
---Is affordable, preferably around/under $50
---Can fit ATX PSU and mobo
---Supports Corsair CX ATX PSU Series
---Has a dual bay usage compatibility for 750 Ti Superclocked graphics, using this mobo http://www.gigabyte.us/products/product-page.aspx?pid=4343&dl=1#ov
---That the mobo provided above will fit the case suggested, according to sound, usb, etc jacks
PS: Please take the time to also look on ebay for these parts, as ebay often sells items for under-normal-price.
your rosewill pc case have Up to 11 inch or 280mm in length maximum
and CPU Cooler Clearance of Up to 6.2 inch or 160mm
depend on which model of gtx 750 TI it should fit
I am buying the single core 750: http://www.ebay.com/itm/EVGA-GeForce-GTX-750-Superclocked-Graphic-Card/191552086810?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D30004%26meid%3D105a53b6d95d466a97dbc26118fb5b03%26pid%3D100011%26rk%3D1%26rkt%3D10%26sd%3D201319286841
And also, what has a max length in 11 in.? And are you saying this is the right case to do the job?
And if you will, may you provide a large fan for this?
Thanks 😛
Ok, I will get the Rosewill case, and I already found a fan, and everything else. All compatible.
This thread is now closed.
