PC build help
Just a few suggestions:
- No need 3rd party cpu cooler;
- A good H97 motherboard is enough;
- Extra money go for a 4GB GPU because some games just need more than 2GB for 1080p.
- Extra money will buy you a far better psu too.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($174.99 @ SuperBiiz)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($79.99 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($48.80 @ Amazon)
Video Card: Gigabyte GeForce GTX 960 4GB Video Card ($209.99 @ SuperBiiz)
Case: Cooler Master HAF 912 ATX Mid Tower Case ($52.99 @...
Case: Cooler Master HAF 912 ATX Mid Tower Case ($52.99 @ SuperBiiz)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($55.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM (64-bit) ($94.99 @ Adorama)
Total: $717.74
Generated by PCPartPicker 2015-12-15 15:24 EST-0500
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130779&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
and
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130788&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
But i am really liking what filippi posted only thing i changed was the gpu from gigabyte to evga that i cant help i will always be and die a evga fan boy. Thank yall so much with the help and some things to look at. Much appreciated
Yeah i just got myself the evga 850w g2 about a month ago but i looked up the xfx u linked and its made by seasonic ive read amazing things about seasonic. i did have one more question the mobo you linked ive never had a micro atx board and as far as i know the only difference is less pci slots. Anything other than that i should know before buying a micro board?
Both are very similar parts.
http://motherboards.specout.com/compare/3003-3004/Asrock-H97-Pro4-vs-Asrock-H97M-Pro4
