PC build help
has18
7
i want to know if my pc build wil not get a bottleneck.
my specs:
AMD FX-6300
GIGABYTE GeForce GTX 960 OC WindForce 2X 4GB
HyperX Savage 8GB DDR3 1600MHz
Motherboard ASRock 980DE3/U3S3 R2.0
eagate Desktop HDD 1TB 7200RPM
450 w power suply
the 6300 might hold back the 980 a littl bit, but not enough to be a serious concern.
how many monitors will you be using? and what resolutions?
If its a single 1920x1080 screen, the 980 is serious overkill for it (a R9 380 or GTX 960 would do for that resolution)
i have a 960 4gb not a 980 and i wil use one monitor 900p resolution. Thank you for response.
