PC Build Help!!!!!
dro371
19
Hey guys so here is my current build: http://pcpartpicker.com/list/JVNrr7
And here is my upgrade list: http://pcpartpicker.com/list/tc2p2R
First, I want to know if these are good upgrades? (I'm reusing some parts to save money)
Second, my current build is LOUD. Is this new build going to be quieter, and if not, how should I make it quieter? All my friends complain of the background noise when we voice chat, and I personally find the noise annoying as well.
Thanks for the help, and feel free to leave suggestions
The build doesn't have a power supply, are you going to re-use your Enermax? The H110 motherboard has limited expansion, but if you don't plan to add anything else it will be fine. The T2 cooler is a step up from the...
if silent or near silent is the goal, I would suggest a twin fan card (GPU). a single fan will have to spin faster and thus louder than two fans at a slower speed pushing the same or greater amounts of air.
that is a 65W CPU you can get a passive cooler (no fan) this would also cut down on the noise.
What is wrong with the first case?
whatever case you decide get the largest case fans you can. typically the larger the fan the quieter.
the Hard drive, PSU, CD-ROM, and fans (including card/case/cpu) are the noise sources in a computer, address what you can.
The build doesn't have a power supply, are you going to re-use your Enermax? The H110 motherboard has limited expansion, but if you don't plan to add anything else it will be fine. The T2 cooler is a step up from the noisy stock cooler. I'd get a dual fan GTX 1060, single fan versions are noisy. Add a couple of quiet 140mm fans to the front and you'll be set. I'd go for the MX300 SSD, $1 less and larger capacity.
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor ($214.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper T2 54.8 CFM Sleeve Bearing CPU Cooler ($16.89 @ SuperBiiz)
Motherboard: MSI H110M Gaming Micro ATX LGA1151 Motherboard ($59.99 @ Amazon)
Memory: *Mushkin Blackline 16GB (2 x 8GB) DDR4-2400 Memory ($59.99 @ Newegg)
Storage: Crucial MX300 275GB 2.5" Solid State Drive ($67.99 @ SuperBiiz)
Video Card: *Gigabyte GeForce GTX 1060 6GB 6GB D5 6G Video Card ($254.98 @ Newegg)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case ($66.99 @ SuperBiiz)
Case Fan: Cooler Master R4-S4S-10AK-GP 60.9 CFM 140mm Fan ($6.89 @ OutletPC)
Total: $755.60
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2016-10-02 18:06 EDT-0400
