PC Build Help !!!!!
sheetza_kebab
Commendable
Nov 3, 2016
I have put a list together of parts i would like to be in my new PC build and i am wondering if it would run fine, as in would they work together.
Parts:
CPU- i5-6600K LGA1151 3.5 - 3.9 GHz
CPU COOLING FAN - Cooler Master Hyper 212 Evo CPU Cooler
GPU- MSI NVIDIA GTX 970 Gaming Twin Frozr
PSU- EVGA 650 W G2 GOLD 80+
MOTHERBOARD- MSI Z97 Gaming 3 Intel LGA1150 Z97 ATX Motherboard
RAM- HyperX FURY 16 GB (2 x 8 GB)
SSD- Samsung 750 EVO 250 GB 2.5 inch
HD- Seagate ST1000DM003 3.5 inch 1TB Barracuda Hard Drive
CASE- not decided atm.
it's a good list except for the mainboard.
the mainboard is not compatible with your CPU. I suggest either a Gigabyte Z170 UD3 or a K3 (the K3 being the budget option). with it make sure you buy ddr4 RAM
furthermore I'd change the CM Hyper 212 Evo to a Cryorig H7
and if you don't already own a 970 it's a bad buy as the 1060 6GB is cheaper and faster
if you already own the 970 & ddr3 RAM, keep the Z97 board but go for a i5-4690k instead
So with the suggestions i should have the updated components list:
CPU COOLER- Cryorig H7
GPU-Gigabyte GeForce GTX 1060
MOTHERBOARD- Gigabyte GA-Z170X-UD3 Motherboard
RAM- Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4
so i only have the 1tb since i'm building a whole new one so i will be buying all new parts basically and my budget is around like £1200 at the most but hoping to get it around £1000
This is pretty much all you need. :)
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor (£210.00 @ Amazon UK)
CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler (£29.99 @ Novatech)
Motherboard: Gigabyte GA-Z170-Gaming K3-EU ATX LGA1151 Motherboard (£100.80 @ CCL Computers)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory (£67.99 @ Novatech)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive (£85.97 @ BT Shop)
Video Card: Palit GeForce GTX 1070 8GB GameRock Video Card (£389.99 @ Amazon UK)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case (£66.94 @ CCL Computers)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply (£82.40 @ CCL Computers)
Total: £1034.08
Generated by PCPartPicker 2016-11-03 23:38 GMT+0000
