A AceMovie Commendable Dec 14, 2016 50 0 1,640 Jan 4, 2017 #1 Is there a way to turn on the PC fans so the LED's light up but the CPU does not turn on? The CPU socket header is inside and it would be messy. Any suggestions?
Solution Multipack Jan 4, 2017 You'd need to use something like this.. http://www.ebay.com/itm/External-MOLEX-Power-Supply-US-SELLER-12V-DC-4-Pin-Adapter-Cable-Cord-NEW-/360170366699
Multipack Honorable Sep 5, 2016 4,283 3 9,960 Jan 4, 2017 #2 Is it the CPU cooler fan or a case fan? But the short answer is no, not without using an externally powered fan hub, but if its the cooler fan it should stay in the CPU_fan header.. Upvote 0 Downvote
A AceMovie Commendable Dec 14, 2016 50 0 1,640 Jan 4, 2017 #3 Multipack : Is it the CPU cooler fan or a case fan? But the short answer is no, not without using an externally powered fan hub, but if its the cooler fan it should stay in the CPU_fan header.. Case fan Upvote 0 Downvote
Multipack Honorable Sep 5, 2016 4,283 3 9,960 Jan 4, 2017 Solution #4 You'd need to use something like this.. http://www.ebay.com/itm/External-MOLEX-Power-Supply-US-SELLER-12V-DC-4-Pin-Adapter-Cable-Cord-NEW-/360170366699 Upvote 0 Downvote Solution
