Pc build help!!!!
Aug 23, 2014
201
I need help to decide the components for my pc build.
1st build is
R5 1400
16gb team dark 3000mhz ram
MSI B350 tomahawk arctic
Asus strix RX570
Cooler master spec 03 case
corsair vs450 power supply.
2nd build is
R5 1600
Msi B350 tomahawk arctic
Sapphire rx 580
Corsair vs450 power supply
MY query is will the 2nd build give me more fps and by how much and does it justify paying more for it.
BTW the reason I am buying 16gb ram is because the very fast 8gb ram is just 15$ cheaper 16gb ram
Naturally the second one with faster CPU and better GPU will result in better FPS for deamanding games.
Agreed you need a better PSU, should be trying to get a 550w for a 580 anyways.
Corsair CX550 is the minimum I would recommend for quality, seasonic m12ii or s12ii (520w is fine) or EVGA B2/G2/G3 (not n1/w1/b1/g1).
