I currently have a PC that I built last year that I am struggling to use for streaming and gameplay. Last year I that I was alittle green at what I was purchasing and thought I was on a good start. But I am running into trouble and need some help trying to see what needs to be done in regards to upgrading the components.
Here is the layout of whats current installed.
Windows 10 Pro 64-bit
AMD FX-8300 Vishera 32nm Technology
16.0GB Dual-Channel DDR3 @ 669MHz
Gigabyte Technology Co. Ltd. GA-990FX-GAMING (CPU 1)
2047MB NVIDIA GeForce GT 710 (MSI)
931GB Seagate ST31000528AS (SATA)
465GB Western Digital WDC WD5000AAKX-22ERMA0 (SATA)
750 PSu
I'm on a very tight budget and need to know what can be done to allow this to handle streaming and gameplay. Any information is appreciated!
I like the feedback would you suggest this Would you suggest this https://www.newegg.com/Product/Product.aspx?Item=N82E16814125919
750 PSu
