Pc Build Help
hystely
4
I really want to make my first build a great and good investment. I'm trying to keep the budget below $1500. I already have a Gtx 1080 but I included it for compatibility reasons. I want to stream and play games at 144 fps. So I need it to be powerful enough to do both. If you have the time, take a look at the build and give me any advice on it such as better parts. Links are below! TThank you!
Link to build: https://pcpartpicker.com/list/fDRLVY
cooler too weak for any overclocking
psu is poor quality
ram speed too slow, 3200 is better
If gaming is major usage, I will go for I5-8600k instead and spend on a gsync 1440p 144hz monitor to go with GTX 1080
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor ($259.88 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler ($34.89 @ OutletPC)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard ($125.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($200.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive ($89.99 @ B&H)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($72.33 @ Amazon)
Video Card: NVIDIA - GeForce GTX 1080 8GB Founders Edition Video Card
Case: Corsair - 750D ATX Full Tower Case ($139.99 @ Newegg)
Power Supply: Corsair - TXM Gold 650W 80+ Gold Certified Semi-Modular ATX Power Supply ($69.99 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($89.89 @ OutletPC)
Monitor: Dell - S2716DG 27.0" 2560x1440 144Hz Monitor ($460.95 @ Amazon)
Total: $1544.88
Generated by PCPartPicker 2018-01-22 14:35 EST-0500
hystely
4
Hey! Thanks for the reply and advice. Ive decided to stick with the 8700 for streaming purposes (because thats mainly why im building a new pc) and ive took your advice on changing the PSU! Ive decided to go with Corsair - RMx 750W 80+ Gold. Ive looked at reviews and it seems to be a pretty solid choice while keeping the noise down. Unfortunately, upgrading my ramsticks to 3200 isnt in my price range.... :/ and the ones i already have are rgb :D. So it will have to do for now. Thanks for your advice and time, if you have any further suggestions to the adjustments ive made, please reply :D
New link: https://pcpartpicker.com/list/rj4d8K
