*PC Build Help*
Andrew CC
13
5
10,515
Dear Support,
I have built a computer before, but the motherboard (I think) died. Instead of just fixing it, I want to fix and upgrade at the same time. So I just need insight of my part list.
{I already own my CPU, PSU, Ram, Hard drive, GPU, and 2 fans I took off the old case}
For my list I was looking at my Pentium G-4620, WD Blue 7200 Rpm 3.5" Hard drive, 16 GB of 4X4 HyperX Furys (I think 2400,) My EVGA 500w PSU, Zotac 1050 Mini, and 2 random fans I think i'm going to just throw away.
For the parts I want to pick up, I want a B250 LGA 1151 Gaming Pro Carbon motherboard, Cooler Master Hyper 212 EVO 82.9 CFM CPU Cooler, Cooler Master MasterBox Pro 5 RGB Mid-Tower PC Case 3 RGB Fans 120mm, and some thermal paste.
The parts I already own correspond great, but I was hoping if whoever is reading this can just 'go over' the parts I want, and compatibility with the parts I already own.
should be fine, just becareful about the hyper evo212 hitting your ram, you may have to adjust the fan position a bit higher.
anyhow, assemble your mobo outside first, and see if you have any clearance issue with cpu cooler and your ram.
