Pc build help
Dec 4, 2018
Pc parts:
Cpu Intel Core i5-8600K Hexa-Core 3.6GHz c/ Turbo 4.3GHz 9MB Skt1151
Gpu MSI GeForce GTX 1070 Gaming X 8G
Motherboard:Motherboard ATX MSI Z370-A PRO
Ram RAM HyperX Fury 16GB (1x16GB) DDR4-2666MHz CL16 Branca
SSD:SSD 2.5" Western Digital Green Sata 240GB TLC SATA
Hard Drive: 3.5" Seagate Barracuda 1TB 7200RPM 64MB SATA III
Cooler CPU:Cooler CPU Cooler Master Hyper 212 LED Turbo Black Top Cover
Thermal paste: Nox TG-1 4g
Case:
Fans:
Keybord:mechanical keyboard Nox Krom Kernel TKL RGB (PT)
Monitor:Monitor Asus VG248QZ TN 24" FHD 16:9 144Hz
Headset:Headset Asus Cerberus Preto
Power supply:Nox Hummer X750W 80 PLUS Gold Full Modular
Guys sorry if im bothering you, but im going to buy a pc this christmas and i have been choosing the parts and i think im pretty much done.
I was wondering if you could help me since i dont know too much about this stuff.
Is everything compatible? If not what can i replace?
I would also apreciate help choosing a case and fans because i really dont know what is the best for this build.
Ps:this is everything im planning to buy, if there is anything missing please tell me.
I would like to not go past too much this price range as well if possible.
I usually play games like csgo, rainbow six siege, overwatch, call of duty, PUBG, fortnite, etc..
Im not planning to overclock btw.
Thank you in advance!
Since your budget is 1500 Euros with monitor, etc... you might want to look at going with AMD.
CPU: AMD - Ryzen 5 2600X 3.6 GHz 6-Core Processor (€215.95 @ Amazon Espana)
Motherboard: Gigabyte - B450M DS3H Micro ATX AM4 Motherboard (€76.18 @ Amazon Espana)
Memory: Patriot - Viper 4 16 GB (2 x 8 GB) DDR4-3000 Memory (€132.97 @ Amazon Espana)
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive (€83.23 @ Amazon Espana)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive (€61.50 @ Amazon Espana)
Video Card: MSI - GeForce GTX 1070 8 GB Video Card (€438.94 @...
If you don't plan on overclocking, you can drop down your hardware. Like getting a non-K version of the processor, you can get by with a B360 chipset motherboard, no need for an aftermarket cooler, thermal paste comes pre-applied on the stock cooler. I also would spend more on the SSD and a larger storage(HDD) drive.
What your:
Budget?
Location?
Preferred site of purchase?
Budget: i would like not to go past 1500 euros too much(counting with keyboard, monitor and what i posted)
Location😛ortugal
Site: i dont really have any preference, i will choose the one that seems to be the best to me
How larger does the ssd and hdd have to be in your opinion?
Could you give an example? i dont know a lot about power supplies
I plan on using it mostly for gaming, is the 500Gb ssd really a must?(knowing im trying not to spend much more then 1500 euros)
Video Card: MSI - GeForce GTX 1070 8 GB Video Card (€438.94 @ PC Componentes)
Case: Fractal Design - Focus G Mini (Black) MicroATX Mini Tower Case (€57.91 @ Alternate)
Power Supply: SeaSonic - FOCUS Plus Gold 550 W 80+ Gold Certified Fully-Modular ATX Power Supply (€96.52 @ Amazon Espana)
Case Fan: Fractal Design - GP12-BK 52.3 CFM 120mm Fan (€10.25 @ Amazon Espana)
Total: €1173.45
Generated by PCPartPicker 2018-12-04 17:44 CET+0100
These are prices based in Spain so in Portugal they will probably be different, but this allows for over 300 Euros for the other parts. The 500GB SSD is a smart idea now of days because then you can install a couple games on it, whereas with a 240 you will be constrained for space.
Wow, thank you so much!
I see a lot of people(a lot of my friends) choose intel over amd, is there any major reason to that? That is why i went and chose an intel processor and not amd, since i thought they would not be as good. Is there any reason to that or its just preference?
Prior to the release of the AMD Ryzen line of CPUs, Intel was far faster than AMD. Once the Ryzen 1000 series was released the difference in performance went from >60% for Intel to 5-10% for Intel, and now about 3-7% for Intel with the Ryzen 2000 series. When it comes to price/performance that is completely in AMDs favor now.
WOw, really didnt know that, thank you!
So the difference in performance should be almost nonexistent right?
I noticed u didnt put a cpu cooler and thermal paste in there, is that not necessary?(sorry if im dumb about this kind of things)
Thank you again!
Prior to the release of the AMD Ryzen line of CPUs, Intel was far faster than AMD. Once the Ryzen 1000 series was released the difference in performance went from >60% for Intel to 5-10% for Intel, and now about 3-7% for Intel with the Ryzen 2000 series. When it comes to price/performance that is completely in AMDs favor now. [/quotemsg]
Thank you again![/quotemsg]
The AMD CPUs, specifically all Ryzen 2000 series and non X 1000 series, come with a cooler that is actually very good for a boxed cooler. The cooler will have thermal paste already applied to it as well so you don't have to worry about that.
The AMD CPUs, specifically all Ryzen 2000 series and non X 1000 series, come with a cooler that is actually very good for a boxed cooler. The cooler will have thermal paste already applied to it as well so you don't have to worry about that.[/quotemsg]
Oh cool!.
Thank you so much for your help!!
I'm sorry but what does that mean? maybe i got lost in the translation but does that mean the performance is somehow too different? ahaha
What he is saying is that the i5-8600K will be about 5% faster than the Ryzen 2600X at 1080p gaming, for ~10% price increase on just the CPU. However, you will not notice any difference even with a 144Hz monitor.
Yes, I'm saying there is a difference and Intel is usually faster. Sometimes not by any at all and other times by a noticeable amount and everywhere in between. All depends on the game. Unless you are simply watching your frame rate counter all the time you typically won't notice any difference.
CPU: Intel - Core i7-8700 3.2 GHz 6-Core Processor (€379.00 @ Amazon Espana)
Motherboard: MSI - H310M PRO-VH Micro ATX LGA1151 Motherboard (€59.89 @ Amazon Espana)
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-2666 Memory (€131.82 @ Alternate)
Total: €1247.31
Generated by PCPartPicker 2018-12-04 20:54 CET+0100
