Question PC build help
Jun 6, 2019
Hi! so i have never build a pc, and i have been planning to do so for quite some time, and would like to know if my chosen parts would fit together and work well? And if i would be able to play all the newer games with 60+fps stable? thanks! :)
Intel Core i5-8400
Nvidia GeForce RTX 2080 Ti
GIGABYTE H370 HD3
Thermaltake View 71 RGB 4-Sided Tempered Glass Vertical GPU Modular E-ATX Gaming Full Tower Computer Case with 3 RGB LED Riing Fan Pre-installed CA-1I7-00F1WN-01
Samsung 860 QVO MZ-76Q2T0BW 2TB
Corsair Dominator Platinum RGB DDR4 3200MHz 2x16GB (CMT32GX4M2C3200C16)
Corsair RM850x 850W
Patryk_12
Commendable
Jun 13, 2017
164
Really nice build but to make it more future proof i'd upgrade the cpu to a solid 9th gen intel as the i5-8400 is decently strong but i would suspect it to have a certain degree of difficulty with next gen games. But yes basically every current game will run +60 fps
