Question PC Build Help
Jul 9, 2019
Hello All,
I have finally decided to make the switch from console gaming to PC gaming. My issue is I have been overwhelmed with information from watching countless hours of YouTube and I'm not to sure on what I should really be looking for..
I would love a PC that is able to play AAA games at 1440p. I have a budget of $3500AUD.
If anyone has any advice or recommendations they could share with me that would be much appreciated..
TYIA
hang-the-9
Are you looking to buy one or build one from parts? Building will save you hundreds.
For 1440p at 60fps you are looking at a higher end video card, Nvidia 2070/1070 class. Rest is not too hard, a system with a good video card in a pre-built should have a CPU to match it, just make sure the power supply is good quality (reviews are easy to find online) and a good size solid state drive, 500gb or larger. 1TB solid states are pretty cheap now, many models in the $100 range. For a higher budget like yours a 1TB SSD and a second standard drive for backup is easy to get.
Reactions: NewGuy2Tech
