Hello I am new to pc building, I am trying to get a good gaming build that can also be used to record and make videos.
GPU : MSI Gaming GeForce RTX 3060 12GB GDDR6 PCI Express 4.0 Video Card RTX 3060 Gaming X 12G
CPU : DO NOT HAVE ONE (I think a Ryzen 5 5600 would go good with this? Let me know what you think)
RAM : Corsair Vengeance RGB Pro 32GB (2x16GB) DDR4 3200 (PC4-25600) C16 Desktop Memory - Black
PSU : DO NOT HAVE ONE (I have no idea how much WAT PSU I will need, from what I have seen I will need one that is over 550WAT, let me know what you think)
MOBO : DO NOT HAVE ONE ( Once again, I dont really know on this I do know that it needs to the right gen so I can use my CPU and that my ram needs to be able to support it)
CASE : DO NOT HAVE ONE (I have no idea on this one, let me know please)
STORAGE : I have two HHD's that have 2tbs on them, so in total I have 4tb's for HHDs. I know I need to switch to SSDs but for now I would like to stick with these to save some money for now.
If you need more info please let me know, I tried to figure this out on my own but I'm running into issues and I really don't know what to do, if you could help I would really appreciate it. (I got the gpu at a Pawn Shop for $300 if your wandering, yes it's real it was tested everything works perfect on it)
EDIT : This is what I have so far : BUILDHERE
Below is important Info that I think is helpful
- Budget is around $300-400 if possible CAN GO HIGHER
- PC will be used for GAMING and Recording/Making Videos at least at 1080p 60FPS
- I do not need to buy any Monitors or mice, etc. I have these items
- Don't need a OS/ Will be using Windows I have it.
- I can buy off of, Amazon / Best Buy / Newegg
- I am in the USA
- Would like to get a AMD CPU
- Monitor Resolution will be mainly 1080p
Below is my current items for this build
