This'll be the first PC I've ever built for myself. I'm very concerned with the quality of parts, yet am for the most part unfamiliar with modern parts manufactures.
I could greatly use some advice from people who are more experienced than I am.
(I have a few weeks before I'll actually be able to buy everything, so I have a while to mull over it. Here's what I have so far.)
Motherboard: ASUS P5Q LGA 775 Intel P45 ATX http://www.newegg.com/Product/Product.aspx?Item=N82E16813131295
I'm fairly content with this, I've heard good things about the intel chipsets rather than the nVidia nForce ones. I decided against the Pro because I don't believe I'll need to CrossFire in the future, and tend to lean toward nVidia anyways. I'm open to suggestion given good reason
CPU: Intel Core 2 Duo E8400 Wolfdale 3.0GHz http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
Also pretty certain on this, there's the 3.16 and 3.33 but it seems silly to spend the extra just for that, especially if I decide to overclock in the future.
RAM: OCZ Reaper HPC Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 http://www.newegg.com/Product/Product.aspx?Item=N82E16820227267
From what I've been able to infer OCZ is reputable RAM manufacturer, and that DD2 800 should be just fine despite that the motherboard supports faster. Very open to suggestions regarding this based on price/performance/reliability
GPU: EVGA 512-P3-N975-AR GeForce 9800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 http://www.newegg.com/Product/Product.aspx?Item=N82E16814130380
I'm pretty much out of the loop when it comes to newer GPUs, but this seemd to be the best for price/performance I could find from nVidia. (I'm clueless about ATI's line at this price range) Also very open to suggestions here.
PSU: CORSAIR CMPSU-650TX 650W http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
This is probably what I'm the most lost about here. Quite a few questions regarding this: Is Corsair any good with their PSUs? Will this PSU power this system sufficiently? Is it good for the price, could I find a similar/better PSU for cheaper? What if I want to upgrade in the future, say a higher end quad core, or a higher end GPU?
Case: COOLER MASTER Centurion 5 CAC-T05-UW http://www.newegg.com/Product/Product.aspx?Item=N82E16811119068
-or-
Antec Three Hundred http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
Pretty unsure here as well, I wanted to spend less than $100 while still getting a quality case. Which of these would generally be considered better quality if at all? Also unsure if all my components will fit these cases.
HDD: Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM http://www.newegg.com/Product/Product.aspx?Item=N82E16822148288
This is pretty flexible, I have no personal preference in brand but I want a good sized HDD for the price without sacrificing quality. (Though I guess that generally goes without saying for anyone, eh?) Once again, open to suggestions.
Monitor: Acer X193W+BD Black 19" 5ms Widescreen LCD http://www.newegg.com/Product/Product.aspx?Item=N82E16824009127
The monitor I'm currently stuck with is so godawfully godawful... well, let's just assume I don't have one. This seemed to be a really nice monitor for the price based on the specs and reviews. Thoughts? could I get a decent one for cheaper?
Should everything listed be compatible? Something I've overlooked completely? What sort of performance might I expect with this setup? I'm an avid gamer so I'm concerned with gaming performance mostly.
I'll have a budget of about $950, these parts are grazing that very tediously based on current newegg prices. Sorry for being so long winded, but this is important to me! Thanks in advance.
-or-
