I connected all the front panels ( idk if that's the problem) but 1st thing is that my fans won't turn on. The 3 pinned molex cable (for the fan hub I believe) thing from my case is connected to the four pin molex cable to PSU. Oh and the PSU molex this it's like a wire hybrid of sata cable and the end of it connects to PSU and the other end is basically the four spaces for big pins. (That's where I plugged my case molex cable to)
The second thing is the CPU cooler fans won't turn on either. The one pin thing is connected to the header called CPU_FAN. And the two fan wires are connected to the wire that the CPU cooler came with. The USB wire is connected to the 1112 USB on mobo.
The third thing is when I turned on my PSU, the mother board lights green and the GPU lights white. When I press power, nothing else happens.
The fourth thing is for the USB 1314, I have a network adapter connected to it. I also made sure the CPU power wire is connected to the PSU and so is the mobo.
In deep shit, you would be praised so much from me if this works or else I'm fucked.
I have
Asus Z170K motherboard
Asus 1070 Strix
Rosewill Photon 750 Full modular PSU
NZXT phantom 530 Case
H115i CPU cooler
I have
Asus 1070 Strix
H115i CPU cooler
