Hi, im building my first pc for my dad. He would use it for work at home, itunes and for browsing the net.
Here are the parts i will be using:
Case: Corsair CC-9011075-WW Carbide Series 100R Windowed Mid-Tower ATX Computer Case - Black
Cpu: Intel Pentium Dual-Core G4400 3.3 GHz Processor CPU
CPU Cooler: Standard cooler that comes with the processor
Motherboard: Asus B150M-C Motherboard (Socket 1151, B150, DDR4, S-ATA 600, Micro ATX)
RAM: Crucial 8GB DDR4 2133 MT/s (PC4-17000) DR x8 DIMM 288-Pin - CT8G4DFD8213 (single stick)
SSD: ADATA SU800 128GB 3D-NAND 100TB TBW Long-Endurance 560MB/s Read High Speed 2.5 Inch SATA III Solid State Drive (ASU800SS-128GT-C)
HDD: WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch
Wifi Card: TP-LINK TL-WN881ND 300 Mbps Wireless N PCI Express Adapter with Two Antennas
PSU: Corsair CP-9020049-UK VS Series ATX/EPS 80 PLUS Power Supply Unit, 450 W
Optical Drive: ASUS Internal DVD Writer DRW-24D5MT (BOX)
Windows 7/10 (not sure yet)
Thats all the parts. Are they compatible? did i miss anything out? Also, if you think some of the components are too good/not good enough for simple day to day workings then feel free to recommend some alternative components.
Lastly, i want to install windows 7/10 and have it as my boot drive. Is this easy to do? I want to use the HDD for most other things that will be on the pc.
Thankyou
Thankyou
