Pc Build, please help !
Taoroz
Commendable
Feb 16, 2016
21
Hello i was wondering if anyone can tell me if these computer parts are compatible. thank you in advance.
Case - Corsair carbide SPEC-01 Black
Storage - WD Blue 3.5" 1TB
Memory - 2x4GB DDR4 2133 G.Skill ripjaws
GPU - Asus Strix gtx970
CPU - Intel core i5 6400
Motherboard - Gigabyte H170-HD3 Intel H170
They are, however I'd suggest investing in i5-6500, better performance for the price, also you might want to consider getting the r9 390 since this motherboard supports crossfire (and not sli) and it can give you a better upgrade path.
thanks man will look into it.
