[SOLVED] PC Build Problem
Jan 28, 2019
7
Hello!
I just built a PC for the first time and had no issues putting it together and getting the fans up and running. However, when I connect it to the monitor, it says no signal. I have no idea what to do.
If you could please help that would be greatly appreciated!
Then that means either your ram, cpu, motherboard or psu is messed up.
Take board out of case. Strip it to 1 stick of ram (in whatever slot the manual says to use) the cpu, and CPU cooler and see if it'll boot.
It's plugged into the 1050 not the motherboard and I checked the CPU and motherboard and there both working
Nope I cycled through all the RAM and it never booted
