pc build review
May 29, 2018
what do you think of this build 1st timer
Intel - Core i5-8400 2.8GHz 6-Core Processor
Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Gigabyte - Z370M D3H (rev. 1.0) Micro ATX LGA1151 Motherboard
Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory
Western Digital - Blue 250GB 2.5" Solid State Drive
Gigabyte - GeForce GTX 1050 2GB OC Video Card
Cooler Master - MasterBox Pro 5 RGB ATX Mid Tower Case
EVGA - 600B 600W 80+ Bronze Certified ATX Power Supply
Very good build though if you could stretch to the the 1050ti that would help, and one more stretch is the ADATA SX8200 240GB NVMe M.2 SSD which is $99 but reads at 3000 MB/s and writes at 1100MB/s compared to the WD Blue which reads at 540 MB/s and writes at 500 MB/s....The SSD is not critical though as you probably wont really feel the difference...Its just such a good price!
Overall though, it is a good build...
I would keep the stock cooler, remove the 212 and change the mobo to a b360 to accommodate a gtx 1060.
U have the nzxt s340 white for 50 bucks.
The evga 600b is a bad psu. Would buy a seasonic m12 620 or corsair cx/cxm 550.
The ssd is also not a good choice. Go with the crucial mx500.
