Question Pc Build water cooling?
cactusgames14
114
https://pcpartpicker.com/list/KcDZTC
I have decided to build a pc like this one in the link above and had a question are all the components compatible and with this case and Motherboard can I have a top mounted radiator or does it have to go in the front of the case I did check the website and it says I can top mount a radiator with fans but will I have enough space bc I have watched multiple yt videos with this case and same watercooler and all of them front mounted the radiator so idk if it will fit?
I'm also looking into building my first custom loop, I'd high advise to not buy a 2080 rn. The price will drop extremely once the 3080ti comes out. You'll be able to get a 2080ti for the price of the super if not for less. Once i get any info on the custom water loop ill send a link to the post i just made.
