Pc Bulding Noob Needs Help Choosing Parts (Badly)
mcarras
5
So i know enough about pcs to build one (Yotube helps), im just bad at knowing wich parts are actually good, or even compatible. I"m looking to spend about 700$ (if its more its ok, just want it to be good), and i would like to put 2 graphic cards on it, a gtx 750ti that i already have, and another one id buy(maybe a 950).
Any help? I really feel lost when talking about motherboards, rams and processors working together
First thing to cover here is the GTX 750Ti which is not capable of SLI (NVidia's term for operation in tandem with another GPU). You would need to get a different graphics card or just run the one 750Ti.
With that in mind, do you want to build with a different graphics card or a build to support the 750Ti? (I would personally opt for the latter for now, change the GPU later)
Yeah, i think i would like to get another graphics card then, i wanted to use the 750ti too just so it wasnt just sitting in a box for the rest of its life, but id like to spend the 700$ on the rest of the computer, then buy another gpu that would replace the 750.
Any other advice on what to build around this budget?:)
Damn, you sir are actually the best, THANK YOU A LOT! 😀
