PC Case and CPU Cooler for Build
CorMazz
29
I am trying to build a pc with the parts in the link below. The case I have chosen is out of stock, and I would like to find a similar case for a similar price. As for the CPU cooler, I want a water cooler with adequate cooling potential for an overclocked i5 8600 that fits in the case and and isn't more than $50-60. I have been looking, but cannot find much. Thank you.
https://pcpartpicker.com/user/CorMazz/saved/2vg4CJ
You're not really going to find such a water cooler for that price range of $50-60. You'll need to double it for a good AiO liquid cooler. Now, if you wanted old HSF tech, there are a few that would work well. The only single fan AiO that made Tom's list is the DeepCool Captain 120EX (120mm class) at around $80 USD. The rest are dual-fan models (240mm and 280mm class)
http://www.tomshardware.com/reviews/best-cpu-coolers,4181-2.html
The Zalman Z11 NEO case is apparently in stock now. PCPartPicker has prices for it, and I followed the links for NewEgg and it wsn't noted as out of stock. If that isn't the case you were referring to, what case are you referring to?
On Amazon the Zalman Z11 Neo is available for $45, but it is currently out of stock. I'm scraping together every penny I have so $15 matters.
Okay...
IGNORING AiO for HSF, recommend:
Scythe - FUMA 79.0 CFM CPU Cooler
Scythe - FUMA Rev.B 79.0 CFM CPU Cooler
(both of those are out of stock )
CRYORIG - H5 Ultimate 76.0 CFM CPU Cooler
Change case to: (Note: the Zalman Z11 NEO case on Amazon for your 42.20 price, is also requiring Amazon Prime membership, and still out of stock. With a $50 or less air cooler, you may be able to get it from NewEgg for the same price + $10 shipping)
Raidmax - Viper II ATX Mid Tower Case
low cost cases come with their share of issues, so caveat emptor.
