I recently bought an RX 580 for my 1-year-old gaming rig replacing 1050 TI and there seem to be heating issues when playing games.
Although the card does not reach temps over 75C the fan is spinning over 2000 RPM and is quite noisy. When I opened the side panel I could feel a lot of hot air trapped inside the case. The temperature dropped as soon as I opened the side panel.
Observations:
CSGO - No noticeable heating issues while playing.
Deus Ex Mankind Divided - Problem when staying on the menu for around 10 mins.
Heaven Benchmark Tool - Problem when running benchmarks for around 5 mins.
I think the problem starts when the CPU usage is relatively low. Since the CPU is not getting hot the front case fans are running at low speeds.
Specs:
Graphics Card - Sapphire Pulse RX 580
Case - Cooler Master MasterBox Lite 5 ATX Mid Tower Case
3 x 120mm PWM Front Case Fans
1 x 120mm PWM Exhaust Case Fan
Motherboard - MSI B350 TOMAHAWK ATX AM4
Processor - Ryzen 5 1600
What works:
Keeping the front panel open. However cannot have it opened all the time as the case fans are mounted on the exterior and can get damaged by accident.
So few questions I had in mind:
Any chance there is something wrong with my new GPU?
Any ideas on how I can mod my front panel to provide better cooling?
Is it possible to set up the fan curves to pump in more air when the GPU is hot and not the CPU?
Observations:
Specs:
What works:
