PC Case help
amgraves08
23
Hey all,
I'm looking for some advice on how to choose the best case. I think I need a full tower (Sabertooth 990FX R2 motherboard). Any help would be greatly appreciated!
First, set a budget.
Second, determine what qualities are essential (Location of front i/o panel, ventilation, top or bottom mounted PSU, etc.)
Third, determine which size you want based on the components you have (if you have an aftermarket heatsink/fan assembly, ensure the case is wide enough to fit it).
If you enter all of your components here, it will automatically filter cases accordingly:
pcpartpicker.com
pcpartpicker.com
