Question pc case question, need advice.
R_1
Judicious
Herald
airflow is hindered by the small flow area around the broad panels of glass, the first case has a much greater airflow areas through the mesh front panel. the fans placed in the front will not be as effective as they would be with a mesh computer front panel.
the difference between opening the window an inch versus half way down in a car.
packersfan036
1,398
9
5,295
what do you think of this case? https://www.newegg.com/black-thermaltake-versa-h18-tg-micro-gaming-chassis/p/N82E16811133368?Item=N82E16811133368
