T Tech_TTT Notable Apr 4, 2017 532 0 1,060 Apr 8, 2017 #1 Hello , is there any case around with isolated Area for Radiator? that is , the Air gets in and leaves out in a separate box isolated from the Motherboard Area , fresh cold air in , hot air out without entering the motherboard area at all...
geofelt Titan Oct 9, 2006 56,041 4,843 174,240 Apr 8, 2017 #2 You can buy a separate radiator box like the thermaltake P100 https://www.newegg.com/Product/Product.aspx?Item=N82E16811133303 What do you have that you need to liquid cool? Perhaps there are other solutions. Upvote 0 Downvote
T Tech_TTT Notable Apr 4, 2017 532 0 1,060 Apr 8, 2017 #3 geofelt : You can buy a separate radiator box like the thermaltake P100 https://www.newegg.com/Product/Product.aspx?Item=N82E16811133303 What do you have that you need to liquid cool? Perhaps there are other solutions. Planning on 2x GTX 1080 ti SLI + i7 =>5ghz ... Edit : I never tried multi cooling loops , which is better ? make it all one loop , or 3 separate loops ? Upvote 0 Downvote
